Topics76,798
Posts788,411
Members12,445
Most Online230 Mar 11th, 2023
Posts: 34 Likes: 3
Posts: 34 Likes: 3 |
While re-building my '68 T120 I stumbled into the dark hole of gearbox selector camplate, plunger, spring and holder changes made during the 1968, 69, and 70 model years. I learn a lot from the forums, so I'm always inclined to pay it back and even forward. I know many will think me crazy for diving this deep, but I do think this is useful information for those who want to try to achieve the best shifting possible from the 4-speed gearbox. My report is a pdf which can be downloaded from Google Drive here: https://drive.google.com/file/d/19TLSiaeshLao7b2yNrk9uFTD8l1qUe7w/view?usp=sharing
3 members like this:
Mark Brown, Morgan aka admin, markf |
Posts: 6,725 Likes: 378
Posts: 6,725 Likes: 378 |
jeez, that's fantastic
now do the five speeds.
and other stuff
MikeJ |
Posts: 1,446 Likes: 26
Posts: 1,446 Likes: 26 |
I wonder if there is something like that for the 500 unit.......
Cheers, Wilf
"It's about the ride..."
Posts: 411 Likes: 18
Posts: 411 Likes: 18 |
Wow Mike, very impressive work and very much appreciated. Cheers, Bill
'68 Bonnie, '70 TR6r '74 CL360 trail 70's and minitrails
MikeJ |
Posts: 2,489 Likes: 469
Posts: 2,489 Likes: 469 |
Now go into the different gear and shaft types over those years..................
Posts: 34 Likes: 3
Now go into the different gear and shaft types over those years.................. There is a good wall chart for that (from the factory). Sadly, it does not come with the magnifying glasses needed to read it! I believe both Coventry Spares and JRC offer it to their dealers. I got mine from Dan at Franz & Grubb.
Posts: 914 Likes: 14
Posts: 914 Likes: 14 |
3D TV: A format that lost a format war without even having an opponent. Bikes: '69 T120 on average (1967 rolling frame and 1971 Bonnie engine) + '56 1/2 T110 on average (58 rolling frame - with 55 iron head engine) + 74 T150 Home model.
Posts: 307 Likes: 9
Posts: 307 Likes: 9 |
A big round of applause for Mike for illuminating several facets of Triumph gearboxes which have long been sources of rolling confusion! Great work, MIke, Congratulations on such a useful outcome of your hard work and dedication!
MikeJ |
Posts: 6,423 Likes: 677
Posts: 6,423 Likes: 677 |
Great summary, Mike Well done and thank you. Everyone with a Triumph four speed box should have a copy of your summary---saved in their computer or printed off and filed.
MikeJ |
Posts: 8,303 Likes: 390
Posts: 8,303 Likes: 390 |
Great work Mike! I saved it and I don't even own a four-speed.
Somewhere there must be a guide to upgrades to early five speeds which don't involve replacing the whole thing?
Posts: 585 Likes: 83
Posts: 585 Likes: 83 |
What do you suppose the notches on the cam plate between the gears were for? It would seem to me that it would make it more likely to find a false neutral.
What do you suppose the notches on the cam plate between the gears were for? It would seem to me that it would make it more likely to find a false neutral. Those are just to drive you crazy trying to index the quadrant. Just like the crossover shaft on the T160.
Posts: 34 Likes: 3
What do you suppose the notches on the cam plate between the gears were for? It would seem to me that it would make it more likely to find a false neutral. Great question! I wish I knew. I didn't come across any info in my research to answer that. I bet John Healy knows.
Posts: 34 Likes: 3
I encountered a unique shifting problem after updating to the 1970 Gear Selector Camplate and appropriate plunger, spring, and holder. Without going into the details, what I found (thanks to a conversation with Don Hutchinson and one with Mitch Klempf) was that the Index Plunger Holder (57-2172) needed to have the top machined down to allow the Camplate (57-4055) proper clearance. I have updated my write-up: Triumph 4-Speed Gearbox Changes 1968-70 and the revision can be downloaded from Google Drive: https://drive.google.com/open?id=19TLSiaeshLao7b2yNrk9uFTD8l1qUe7w&authuser=mike%40james5.com&usp=drive_fs[i][/i]
Posts: 1,876 Likes: 51
Posts: 1,876 Likes: 51 |
Mike , Your information was very helpful to me. I found it on Hermit's Bonnie Reference. I am just about ready to button up the tranny - waiting for a clutch rod buushing. Previous owner drove out the bushing for some reason. Thanks very much. Al
Al Eckstadt
